Hank_MI
Jun 06, 2017Explorer
DrewE wrote:
Alternately, if you have a winterize suction inlet, you likely can use that to pump water (or a bleach solution) from a container into the fresh water tank by setting the valves for winterizing and filling at the same time. I think pouring the bleach into the hose is the easier method, though; just remember to wear old clothes unless you're far more neat and coordinated than I am.
That's how I pump a bleach solution into our tank. We do have a gravity feed port but that's hard to dump bleach or bleach solution into without it running down the side of the MH.
Our water tank is between the front and rear axles. I can see it from one of the basement compartments. It has a quarter ball valve to drain it. The low point drains are in the compartment with the water pump and water heater. That probably doesn't help the OP since it's a different manufacturer.
