PButler96
Sep 16, 2022Explorer
TechWriter wrote:blazenpm wrote:
How do yall sanitize you water storage tank.
Per NFPA 1192 Standard on RVs, use 1/4 cup bleach per 15 gal of water (50 ppm ratio). So for a 90 gal RV water tank, you would use 1 1/2 cups of bleach. Run the bleached water throughout the RV plumbing, let it stand for 4 hours, then thoroughly flush with fresh water. For a stronger dose (100 ppm), you would use 1/2 cup of bleach per 15 gal water.
If you don't like using bleach, then you can sanitize your tank with Purogene
On the other hand, if you want to sanitize the water, and not the water tank, then you're talking about adding drops of bleach. Here are the EPA's Recommendations.
Always remember if you do not follow the NFPA 1192 standard to the letter you could very well be run in by the sanitizing police, that's if you don't die first.
38,778 PostsLatest Activity: Jun 10, 2026
