charwan's avatar
charwan
Sat. ant quite working
When it rains it pours. My sat ant quite working also it goes to one sat and when you tell it to go to another it moves and goes back to the same one. It's a hvh L2 04 model. Any help would be appreciated.
  • My 05 L2 sometimes requires dome removal and manual repositioning of the antenna. Then it reverts back to normal trial and error automatic searching OK.
  • dougrainer wrote:
    How about a KVH model?:B I assume by 04 you meant a 14 year old KVH Sat. The bad news is, you will have to connect a Laptop to diagnois any problems with a KVH Sat system. Then once connected to the Laptop, you will have to get KVH tech support on the phone to walk you thru how to read what the screen tells you. VERY time consuming and one of the reasons you will find it hard to find anybody that services the KVH Sat systems. Doug
    I did KVH L 2 04
  • How about a KVH model?:B I assume by 04 you meant a 14 year old KVH Sat. The bad news is, you will have to connect a Laptop to diagnois any problems with a KVH Sat system. Then once connected to the Laptop, you will have to get KVH tech support on the phone to walk you thru how to read what the screen tells you. VERY time consuming and one of the reasons you will find it hard to find anybody that services the KVH Sat systems. Doug
