Im sure alot of you fine folks have run into this. I have the winegard dome type satalite reciever which works fine but is sometimes blocked by trees or whatever. Can you plug like say a tailgater typ...
You should have a switch already installed to switch from Sat, to ANT, to cable. So yes, you can leverage another input, in your example the cable input, and switch your box to cable.
