Im sure alot of you fine folks have run into this. I have the winegard dome type satalite reciever which works fine but is sometimes blocked by trees or whatever. Can you plug like say a tailgater typ...
My Goodness. I did not see that you have a 36LA. My bad. As stated earlier, that is what I have (2013) and the above poster is correct. That site has a lot of good info and people. You will get a lot of specific help to your end result.
You do not need anything special. You need to work through your cable labeling and find the A/B switch that is already installed.
