bullydogs1
Jan 18, 2016Explorer II
The cable they used may not be of high enough quality through the RV...if they did not use RG6 type cable inside the RV itself...the signal will not carry through the cable.
1. Does the cable work fine to give you cable TV to your tv sets?...this determines that the cable is not broken somewhere..
2. If cable works fine, then I would try a known good input to it and connect that cable to your satellite box in which would then go right to your TV...If you don't get anything...then your cable is not strong enough to carry the signal from satellite.
