Executive45
Jan 18, 2016Explorer III
Your second sentence identifies your problem. You're hooking your sat coax to the CABLE outlet. They are not compatible. As you learned, it will not work. I had to run a separate line into the coach with a multiplex switch to get mine to work properly. I did install an A/B switch so I can use the roof antenna most of the time and switch it to B when I need the remote one....good luck..Dennis
