BeaverCamper's avatar
BeaverCamper
Satellite dish install question
I am installing a Dish system on the roof of my 2018 Thor ACE 27.2.
I will use the removable roof mount so I can take the dish down and use it manually should there be trees or other obstructions.
My question is what size and type of screw should I use to attached the mount to the roof. As you can understand I am a little nervous about doing this on a brand new RV. I do have good roof sealant to use on the screws to avoid leaks. Any advice from someone who has done this on screw type as well as other hints would be appreciated.
  • If your mount did not come with screw, #12 2" self tapping sheet metal screws will do. Make sure to apply a bit of your Dicor sealant to each screw prior to install. Seal over top when done.
