hurricane0226 wrote:
I have an Itasca Sunstar 35B. I was given a tailgater satellite system and receiver. I know on the outside wet bay there is a connection for either cable or portable satellite system. On the overhead storage console above the drivers chair is where the receiver connects to the incoming satellite signal. My question is this: in the bedroom, there is a wall plate for the television, which only has a connection for the roof top satellite, But I would like to be able to connect the portable satellite signal there so we can watch tv in the bedroom at night, without having to run a cable from the receiver in drivers side in the inside of the coach where someone will trip over it, anyone with this coach have any Ideas? Thank you
Unless you actually do have 2 separate connection ports outside (one labeled cable and a different one labeled satellite) then the one connection is not interchangeable and is usable for cable only. This connection "may" be able to be modified inside the coach allowing a choice between one or the other but the coach wiring may preclude that.
Since you mention a roof top option, there should also be a way to send the satellite signal from your satellite receiver to the other TV's. You should either have a video switch to select the various TV's or you should have 2 coax cables coming from the roof to each TV. If the second option is how your coach is wired it was designed for you to put a separate receiver at each TV.
