oldmattb's avatar
oldmattb
Scangauge Connector
...Where is it?
I am interested in installing a Scangauge to our 1998 Monaco Windsor with Allison and Cummings. I can't find the connector!
The only exposed port is a 12-pin rectangular port, that does not look like an OBDII. It is labeled "diagnostics," and is under the dash to the right of the steering column.
Concealed under the shift console is a 16-pin port, with a plug and single wire coming out. It does not look like the ports on the Scangauge website, though it IS round..
Am I missing the obvious, or is it really concealed? Where? I hate to be moving wires around without a plan.
Matt B
  • Im guessing your DP doesn't have OBD. Most diesels have a J port, the round connector and the gas scanguage isn't compatible.
    I use a Silverleaf software with a cable to my laptop.
    Its Cummins, not Cummings.
