mikebo wrote:
I had the front end aligned, helped a little but still had the tailwaging. Added a blueox track bar, helped a little more. Added hellwig front and rear sway bars and bilstein HD shocks. Handling is much better and ride is quieter.
In my opinion the trackbar and the shocks made the biggest difference.
The RV community in general will never know which would have the greatest impact for each individual's motor home because it is not practical to test each improvement independantly, especially under identical test conditions. Some people like yourself will add one or two things at a time, then adding more along the way until they are satisfied. I wonder if you installed everything in reverse order, you might also reverse the order of effectiveness.
Just a thought about it. Still very interesting input you have. Thanks for sharing.
