Your comment that the overhang looks like half the length of the coach piqued me. I looked up Winnebago 29T and it says length is a little over 30-ft (360") and wheelbase is 190" which is 53% of length. I'd be interested in what the ratio for your friend's Coachmen is. Without year and model, I couldn't look anything up. That's a short wheelbase and low % for driving stability. For example, our 31-ft (372") has a 218" wheelbase for 59%.
Then I read the whole thread again and your weights aren't listed or I missed them. Ford wants that 32% of loaded weight on the front axle. That is going to be VERY hard to achieve with that 53% wheelbase. That much rear overhang is also going to lead to sway, and sway in a Ford chassis causes it to STEER. When you probably want it not to steer or want it to steer in a different direction.
The Track Bar will help, but if your front axle is light and front tire pressures high, it won't have much direcitonal stability.
What's the condition of the front end in the Liberty? When I was transferring the rental trucks we towed my Dodge van and it tracked ok behind an E350 cube van. A friend had a similar van he'd bought used cheap and when we towed it we had a lot of tugging and wandering. We later found most of the front end parts were worn out.
Suggest you review basics. What are your loaded weights, at least by Axle, ideally by Corner? And are your Tire Pressures set according to the Weights? That said, if you only have 27% (example, we don't know yet) on the front axle, the correct tire pressure isn't going to make it track correctly.
desetrek's 88 coach is the old chassis like our 83 E350 and I tweaked our toe in just a little too. Never had it formally aligned, only checked the toe with a couple straight edges and a measuring tape. Contrary to "the book" these Fords drive better with more Caster and more Toe than the specs.
