TyroneandGladys wrote:
DunnInn wrote:
Weighed it a while back -
front axle - 3480
rear axle - 8420
I'll have to look at the tire sizes tomorrow.
What is the gross axle weight rating for the front axle and what is it for the rear?
I think you are very close to be underloaded on the front axle
I think he is under loaded on the front end. If what I read is true the manufacturer wants minimum 32% on front axle. His numbers above would put him at 29% on the front axle. Mine is very similar and it also is squirrely on the road. I just got mine and haven't check pressures or gotten it aligned. I hope those two things will fix it. I can tell you if it was mine I would replace all 6 tires with good name brand tires. The grand it would cost me would be worth the peace of mind.
