blknomad's avatar
blknomad
screen door shade
I have a 2014 Itasca sunstar 35F. The shade on the screen door refuses to go up. I have removed it from the door but can't seem to disassemble the %$#@ thing without destroying it. It has no markings anywhere. Can someone help??
  • That's it exactly, smooth black fabric. Its raining so I have something to do. Thanks
  • Had the same problem. I sprayed silicone (slide lube)between the shade and the cover and on the ends of the roller then played with it, till it unlocked. Then it rolled up. Then pulled it out and sprayed the fabric (lightly) and wiped it down. Had to do it again a year later (seems I didn't do a thorough job) It's been great for three years now. Seems that dust and dirt will jam the shade against the cover. I did not try to remove the shade from the cover. I could see that would be a handful.
    I hope you are talking about a black, smooth fabric shade. If not ???
  • If its a simple roller shade you can buy a replacement at Lowes or Home Depot. They are quite inexpensive. Take the old one with you so they can cut the replacement to fit.
