Gjac wrote:
If you don't want to use 4 cans put 1/2 a can in a 1/2 gal container and draw from it rather than your 55 gal tank. I would run it to temp to clean the carb then shut off with a full bowel of concentrated Seafoam. Berryman's Chemtool B12 also works to clean carbs and is about 1/2 the price. Does that mean it works half as good?
Great input, if this wasn't about fuel stabilizing, which B12 is not a fuel stabilizer. (And after starting the thread, the OP just said he doesn't need to stabilize the fuel anyway.)
