Dale_Traveling
Jun 26, 2018Explorer II
When I reworked the clearance lights on my coach all that was needed was to remove the assembly including the base gasket and seal the power wire access hole and the fasteners. Used butyl tape around the wire and hole and a dab of liquid sealant on the threads of the hardware. Been leak free every since with no visible exterior sealant necessary.
Check the base gasket carefully for a possible drain or weep hole that you don't want to seal.
