Tom_Barb's avatar
Tom_Barb
Explorer II
Sep 23, 2022
Seat switch
We have a seat that is out of production, it is a Flexseat. (vintage 2000) I need a toggle switch that controls the seat recline switch. It is a two position -- up or down it is not the 6 position that controls the lower portion of the seat..
They are no longer made.
Is there a work around or a different that will work..?
  • See if a standard 2-way momentary switch will work. Should be available at any auto store. If that works you can either modify the seat opening or use that information to locate a similar switch that be a better fit on the internet.
  • There are no numbers on the switch.. Zip ,, nada
    That's part of the problem, no data to research.
  • try a body shop they run into this kind of problem. or numbers on the switch .
  • Are there any model numbers on the switch? That might help to locate some others that have swapped with a newer part.
  • MountainAir05 wrote:
    Tom,
    try this place. I had one go out and had to upgrade to the newer switch.
    Switches
    That isa the 6 way switch.. and the one is just the 2 way switch..
    Tried them already
