Clay L wrote:
dkreuzen wrote:
Clay L wrote:
Since the sensors are just pieces of metal foil attached to the side of the tank with adhesive I don't see how 409 could harm them.
I would look for some residue that might act as a high resistance path between them and confuse the control panel.
SeeLevel says on their web site that if the tank walls get cruddy enough the system will stop indicating so maybe a high resistance path in the wrong place can also cause it to stop working.
The sensors are not foil, they are thin printed circuit boards. But I don't see how come cleaner would kill them.
Aren't they (the thin boards)covered with copper foil?
The ones I put on my last HM about 4 years ago were not and the set I just bought are not either. If you put foil tape over these you would stand a good chance of shorting them out.
