- usersmanualExplorer
Chum lee wrote:
Usually there is no set replacement interval for most soft parts. Regular inspection and knowing what to look for is the key to minimize unexpected roadside issues, but, not a cure all.
From experience, belts and hoses rarely fail without notice, but, it does happen. Usually belts will crack, glaze over, harden, fray, squeal, crackle, slip, come off, need tension adjustment, etc. before they give up. If any combination of the above happens, its time for further investigation. Hoses usually bulge, harden, leak, crack (often from the inside first), etc. Generally, higher heat causes failure before colder hoses, but not always. Using the incorrect coolant can lead to early failures. Bad motor mounts can also lead to premature failures.
Bearings in tensioners, pumps, usually start singing/grinding/vibrating before failure. Misalignment should always catch your attention.
Segmented belts, its best to replace them at or before the recommended time/mileage interval if there is one. When replacing segmented belts, its wise to replace any related tensioners, water pumps, leaky seals etc. at the same time.
Chum lee
what the hell is a segmented belt? R U referring to a serpentine belt?
why is wise to replace a water pump simply because your changing a belt>?all news to me? what is incorrect fluid? - Chum_leeExplorerUsually there is no set replacement interval for most soft parts. Regular inspection and knowing what to look for is the key to minimize unexpected roadside issues, but, not a cure all.
Chum lee - usersmanualExplorer
Trackrig wrote:
usersmanual wrote:
rgatijnet1 wrote:
I have found that when it comes to belts and hoses OEM are best
Nothing wrong with OEM parts, but especially on hoses and belts, you can buy better. I keep my vehicles for a long time. When it comes to hoses I go to silicone hoses, much more expensive, but I've never replaced one of them and I kept my 1983 Chevy diesel for 29 years. If the mfg can save a dime, they will as long as the part will fail after the warranty is off.
Bill
I disagree I have found for the most part over time OEM belts and hoses fit better and last longer its just they usually cost 2x as much - clinedinstjtExplorerMy belt and hoses were 11 years old until I traded for a new Motorhome about 4 weeks ago. Appeared to be in good condition.
- Kayteg1Explorer IILove the pulley where package says "Made in Canada" and mold on the bearing "CHINA"
Technology change and when some things improve, some go downhill.
I had cars with 200,000 miles and factory serpentine belt and hose.
But idle pulley bearing gave up in the mean time.
Bearings used to be lifetime items on the cars, were they not?
So when it comes to belts and hoses >>> Inspect, Inspect, Inspect. - Canadian_RainbiExplorerWe have replaced the serpentine twice in our DP. Both times on the side of the highway, both times in Mexico. :E
The second time at least we had a spare belt. :) According to the mechanic, the second failure was due to the tensioner coming loose. I now have added this to the list of things for our at home mechanic to check during the annual service. - rgatijnet1Explorer III
Snomas wrote:
When do you replace serpintine belt and radiator hoses on
diesel engines? Last year I replaced all heater hoses & tank radiator hoses. Autos are generally 5 years.
Don't forget to keep any eye on the bearings in the belt tensionors and idler pulleys when you replace your belts. They can fail and wipe out the best belt in a matter of a seconds and altho you may be able to find a belt at most parts stores, the pulleys might be more difficult.
If you believe in the OEM being better, you may want to consider what GM does with their parts. I bought an OEM ACDelco idler pulley from the dealer that proudly announced on the package that it was made in Canada. The real truth was that ONLY the pulley itself was made in Canada. The only part of the assembly that ever fails, the bearing, was made in CHINA.
I carry a spare idler pulley and tensionor in my coach.
- pointrowExplorerFunny I have hoses on diesel engines that are 35+ years old. Belts that go 15 years and run in a lot harsher conditions than any rv. Oh and they set for 9 months between seasons.
- GjacExplorer III
rgatijnet1 wrote:
. My OEM serpentine belt was replaced at 10 years and 50,000 miles with a Gates belt it now is 10 years old and still looks new no cracks. The old one had longitutnal cracking and separation. I changed the transmission, rear end,and brake fluid 3 times in 10 years because I can't see what is happening inside. The radiator hoses and other belt has 107,000 miles on them and are 20 years old and show no signs of deterioration. As Ron said they are easy to inspect.
I've had Dayco belts fail at 15,000 miles and I have had Gates belts last twice as long. An inspection to check for cracks should tell you when it is time. - imgoin4itExplorerI replaced the serpentine belt on our coach at about the 6 year mark. Did it on recommendation of a mech at the dealer as he said it was developing fine cracks. Did the compressor belt at same time. I now carry it as a spare and I cannot see any fine cracks in it. Had a trusted mech at place where I get coach serviced nowadays check the radiator hoses. He said they were getting a little hard on our 2007 motor home and that could probably go some longer. We were starting a 5000 mile trip and a friend just had a hose replaced on his same year motor home after being towed to a repair shop. I had him replace all the radiator hoses.
38,761 PostsLatest Activity: Nov 18, 2025
