- TrackrigExplorer II
usersmanual wrote:
rgatijnet1 wrote:
I have found that when it comes to belts and hoses OEM are best
Nothing wrong with OEM parts, but especially on hoses and belts, you can buy better. I keep my vehicles for a long time. When it comes to hoses I go to silicone hoses, much more expensive, but I've never replaced one of them and I kept my 1983 Chevy diesel for 29 years. If the mfg can save a dime, they will as long as the part will fail after the warranty is off.
Bill - Jim_NormanExplorerHmmmm, I don't know what to expect as to the life of working belts, however I will be purchasing and carrying a complete set of belts and filters. Still working out the Spare Tire. Also carrying 2-1/2 Gallons of DEF. Not sure what else I'll load yet.
- theoldwizard1Explorer II50 years ago, that was the norm. One of my "daily drivers" has 19 year old radiator hoses and 10+ year old serpentine belt (the old one is stored with the spare tire; looked good when removed).
I traded in my other car after 10 years with the original hoses and belts. Heck, I only changed the antifreeze once !
Admittedly, neither were diesels.
Carrying spares and clamps is not a bad idea, especially when you can buy the parts online for deep discounts. - lc0338Explorer
usersmanual wrote:
lc0338 wrote:
I guess it all depends on whether you want to replace on side of road or at your convenience. Belts are rubber just like tires and they break down over time. The engine compartment is a pretty harsh environment so I would think 5 years to be a pretty good number... at least to do serious inspections. Serpentine belts are easier to inspect and when you see cracking on the groove side it indicates the rubber has lost it's flexibility. If you believe think 5 years is too often then you are probably one who don't mind replacing on side of road. Remember also that failure modes follow a bell curve shape. Few parts fail at the low side of the curve and a few fail at the high side of the curve... so there will alway's be someone who has a belt or hose that has made it 300,000 miles and 20 years :)
Its rather obvious I was referring to the 5 year deal in my opinion is not a given in the car world. MH as said is more of a inspect and decide on a yearly basis.His 2002 to "repeat" should be replaced
if original. to insinuate that because I may go more than 5 years I like to replace stuff on the side of the road is plain stupid comment on your part.
I don't personally know you so you may be pretty stupid - usersmanualExplorer
rgatijnet1 wrote:
I've had Dayco belts fail at 15,000 miles and I have had Gates belts last twice as long. An inspection to check for cracks should tell you when it is time.
I have found that when it comes to belts and hoses OEM are best - usersmanualExplorer
if original. to insinuate that because I may go more than 5 years I like to replace stuff on the side of the road is plain stupid comment on your part. - rgatijnet1Explorer IIII've had Dayco belts fail at 15,000 miles and I have had Gates belts last twice as long. An inspection to check for cracks should tell you when it is time.
- lc0338ExplorerI guess it all depends on whether you want to replace on side of road or at your convenience. Belts are rubber just like tires and they break down over time. The engine compartment is a pretty harsh environment so I would think 5 years to be a pretty good number... at least to do serious inspections. Serpentine belts are easier to inspect and when you see cracking on the groove side it indicates the rubber has lost it's flexibility. If you believe think 5 years is too often then you are probably one who don't mind replacing on side of road. Remember also that failure modes follow a bell curve shape. Few parts fail at the low side of the curve and a few fail at the high side of the curve... so there will alway's be someone who has a belt or hose that has made it 300,000 miles and 20 years :)
Snomas wrote:
When do you replace serpintine belt and radiator hoses on
diesel engines? Last year I replaced all heater hoses & tank radiator hoses. Autos are generally 5 years.
really who said autos are 5 years? seriously never heard that before?
My belt on my ISL is 8 years old 26000 miles looks and feels like new.I carry a spare though. I looked at the hoses and seem pretty decent yet? at 2002 most likely well overdue
also on edit after thinking about it gassers actually have full upper and lower rad hoses that see extreme pressure from high RPM and heat where as my DP has 80% metal pipe with the blue silicon short hose connecters - big difference in this case
38,738 PostsLatest Activity: Jul 26, 2025
