willald
Jan 11, 2021Explorer II
Service recommendations near Charlotte NC - Ford V10 misfire
The V10 in our 2012 Georgetown (see signature) has developed a misfire.  You can only feel it at idle and when initially accelerating, a slight vibration.  Engine cranks and runs OK once you get going, and neither wife nor daughter even noticed anything was wrong until I pointed out the vibrating that occurs at idle.  Seems like at least one of the 10 cylinders is not hitting.  Check engine light came on after driving about 10 minutes (exercising it Saturday).  The smell of unburnt fuel is very noticeable in the exhaust.
Been through same thing before with a V10 in Ford Excursion that I used to own many years ago. Turned out to be a broken wire going to one of the fuel injectors. Fixed that one myself. Doubt I'll get that lucky this time. Will be looking under the 'doghouse' later today to see if I can tell whats wrong, but I'm guessing it'll be either a coil pack, spark plug, or possibly a busted vacuum hose.
Any suggestions of what else to look for, would be welcome. :)
Now, here's the main question: In case I do decide to take it somewhere to have this fixed, where is a good place for such near Charlotte, NC that will work on the Ford F53 chassis/V10? I've found two places I know that work on them, not sure which is the better option:
1. Classic Ford/Lincoln in Shelby, NC - Been there before for a warranty fix on the V10 years ago, they were great then. But, that was many years ago, and they've changed names/hands since then.
2. Camping World (Formerly Tom Johnson Camping) in Concord, NC - One of only RV dealers around here that has the facilities to do chassis/engine work on Class As, and they do a lot of it. Have never used them for chassis work, though, very leery of ANY Camping world for service work.
Which of these seems like the better choice? Or, might anyone know of a shop around this area that would be better? I realize independent repair shops are typically better, but I can't seem to find any around here that will work on these big rigs. Many auto/truck dealers, independent repair shops, and RV dealers don't have the facilities to handle (or just don't want to deal with) chassis/engine work with these rigs.
As always, all suggestions, opinions, etc. are appreciated and welcome. :)
