willald
Jan 11, 2021Explorer II
BurbMan wrote:
Man it's your lucky day! That broken wire is definitely the misfire, but had it not been for that you never would have looked under the hood and found the fuel leak! Surprised you didn't smell fuel?
Fuel injection runs at very high PSI so you can't just use a "piece of hose", glad you are having the mobile mechanic fix with Ford parts. You might want to have him give the engine a "once over" to see if he sees any other developing problems.
Yeah, we did actually smell fuel, but it was pretty faint, and I figured that was cause of the misfire. A cylinder not firing means some fuel is not getting burnt.
Agree, no way I’d just use hose and rig this. Not with fuel injection pressure. I could get it towed to a repair shop using emergency road side service we have, but I’d have to first back it out of the driveway and get it on the road (they won’t tow it if it’s in your driveway or so I’m told). I didn’t even want to drive it the 100’ out the drive to do that, with it spewing fuel like that! Nah, it ain’t moving again til this gets fixed right.
Definitely gonna have him look everything else over, yes. Does look like this fuel line rupture had some ‘help’’ and didn’t just happen. Looks like it was chewed by a rodent of some kind (can see bite marks on it), so need to make sure nothing else got chewed.
38,780 PostsLatest Activity: Jul 04, 2015
