ford_truck_guy
Mar 05, 2023Nomad
I have a TST, This is. what THEY say to do -
Note: Tire pressure data charts are available on your tire manufactures website.
The high tire pressure alarm should be set approximately 25% above that
setting. If you would like to set the cold tire pressure based on your load
weight, we recommend that you take your vehicle to a local weight station
professional for a more precise cold pressure recommendation that is
based off your load weight.
I run my tires at 115# , when I purchased the TST they did all the set up for me. The first question was what psi do I run at. They set my max pressure alarm at 143.
Is it right??? do they know better than I , I hope so! !
38,782 PostsLatest Activity: Sep 19, 2026
