way2roll wrote:
I had a previous Class A with a built in Macerator that used a smaller hose. I just went to Lowes and got a Cap for the sewer cleanout, a threaded adapter for the hose and drilled a hole in the CAP, put the adapter through and put a PVC nut on the back. It's all schedule 40 stuff so no real risk of a point of failure. I never found a pre-made adapter but for a few bucks was easy enough to make one. It's just plumbing.
Sounds easy enough however the cap for the clean out is under rose bushes and an extension pipe comes from there with the standard fitting on that.When my home was built we had a cleanout put by the street and in the garage. I have found a 90* fitting that his hose can slide into and when fastened to my drain pipe will be pointed skyward.
Thanks for the suggestion.
