Hotdog99ExplorerJan 15, 2017sewer line brokenI have a sewer line that is broke where the waste valve bolts on I have to re place that part and it is glued how do I get it to turn loose
crassterExplorer IIJan 17, 2017I'm with the others. If the pipe is cracked, cut it clean and mount a new dump valve. It should fix with PVC glue. The mount plate should come with the new valve that glues onto the pipe.
Related ContentShould I connect my sewer line when camping?frozen sewer hose and water lineSewer line PVC supportsWiper Fluid in Water linesSEWER LINE AND WIND RESISTENCE
