Hotdog, a lot of times, the drain pipes are just glued into the tanks with silicone caulk and a worn drive clamp. If you can get to the tank, and work the pipe out, you can use it as a pattern for making a new one to where the dump valve bolts up. Not knowing what brand or year your MH is, limits the helpful replies.
