wildmanbaker
Nov 03, 2013Explorer
I would use a little caution in trying to just rotate the sewer connection. Not all of the fittings have an o ring to allow changing the angle of the connection. A lot of the connectors for the valves and waste dumps, are glued to the fittings/pipes, with a o ring at the gap. I have seen the bolt flange with the o ring seal, that allows adjustment also.
38,776 PostsLatest Activity: May 14, 2026
