MNtundraRet
Nov 06, 2013Navigator
tiffinboy wrote:popeye766 wrote:
Turning it around ...OK.......but other wise OUTRAGEOUS.......a new coach ..you should not have to lift a finger.....No excuse.....Failing Quality Control...
the outlet is designed to work this way.U can swivel it in both directions as in out 90 degree,s or down 90 degree,s.so no quality controll issue here.Just a customer not knowing how things work
Let's put the blame were it belongs this time.
IT'S THE DEALER! I'm shouting.
Obviously not a soul there knew how to work the dump station. The #1 thing I would need to know to use a RV. They needed a few days to cut the pipe and repair it?
Time to run the other way if needing an RV or service here. :M
38,775 PostsLatest Activity: May 14, 2026
