Goldencrazy
Oct 05, 2017Explorer
I use it alot and had done three loads the day before it began to stink so I guess it is sloshing as the answer. Someone pointed out that because the washer drain is higher it is easier to lose the water in the p trap than with the the sinks or shower. I suspect location in far rear is also a factor as it can roll or boundce in this gasser.
