et2
May 21, 2014Explorer
Sewer solution
I just purchased this for our MH as our dump connection is literally inches from the ground with the hoses attached. It's been a real pain trying to dump at times as I found myself walking the sewage ...
et2 wrote:atomicglock wrote:
Curiosity question when using the Sewer Solution: There have been campgrounds I've stayed at that did not have the capability to hook up a hose to the water spigot or there was some sort of pedestal type thing with a spring on top and a permanently attached hose/spray nozzle. What does one do then?
Then you probably don't have a sewer hookup anyway. Dump with the same 3" sewer hose like everyone else at the dump station. It's not a permanent fixture if you can't use it. Dump as normal
