tmarcoux wrote:
SO...
I am going to do this process this weekend. Just one question:
Has anyone used a orbital polisher to apply the Barkeeper's? Wondering if that would speed it up without over scrubbing?
I would not use anything mechanical. You are not required to shine the base surface. All one wants to do is remove the dirt, fingerprints, and black stains from the RV.
The red Max Pro will put a shine on the surface and seal it so you want it to be clean. 4 coats should do the trick. Watch out for drips because if not removed right away, they will dry like a run in paint.
