It dries fast, it all depends on the weather. High humidity will take a little longer to dry. I think each coat on mine took between 5 to 10 minutes to dry. By the time I finished the side I was able to go back and start again from the top to the bottom.
The key to applying this is to make sure your cloth is not soaking wet with the Red Max. Wring it out good. I also made sure my cloth was damp (water) before I started using the Red Max because I remembered reading it here to do that.
Take before and after pics, not only because we like to see them , but you will also be able to see the difference from start to finish.
Monika
