fortytwo wrote:
Red MAX Pro and Graphics peeling. Red MAX Pro is damaged by direct sun rays. It has flaked up on my Class C cabover, and on most of the graphic decals that face the south. It is particularly evident on the RED decals; less so on the silver ones.
The damage patterns I have look like it is a heat issue. Red gets warmer than the silver. The only white fiberglass I have showing damage is in the curved portion of the cabover which gets more direct rays than the sides, which get angled rays. Could also be UV, but the locations of the RMP flaking are also the spots most impacted by the intense Florida sun.
I put RMP on the roof of a class A I owned. The summer sun caused almost all of it on the roof to flake off. The sides were not effected.
Florida sun is not the friend of any protective finish I've ever used. RMP holds up better than any other though.
Had the same thing happen on the South facing side of my 5er that is outside all the time. I did a quicky wash and a couple of coats of RMP and look alright not like the original job look like I will have to remove and do that side and add to the good sides.
