EMD360's avatar
EMD360
Shiny RV with Red Max Pro (pics)
How many of you use this stuff? We were getting that chalky finish with faded and peeling graphics. I was waxing it with Meguiars--trying to avoid the graphics and spray them with 303 Protectant instead. I spray the dirt off after almost every trip too. We've only had it 15 months--I hated to see it get "old looking" under my care.
Replant just mentioned Lowes Red Max Pro and I read the links. Wow! Why not take the chance that the fiberglass would be looking shiny and new?
It worked! Here are a few pics.
The graphics bleed out color when washed.
And they were peeling up at the edges. I took a flat razor blade holder and trimmed off the peeling edges--
This is after the trimming. They are a bit ragged in places, but at least no longer peeling.
I used my little power sprayer with TSP in it and scrubbed with Bar Keeper's Friend as recommended.
This is the tire cover with one side is just washed with a sponge and TSP, the other is washed with a green scrubbie and Bar Keeper's Friend. I also used the white scrubbie (1000 grit sandpaper grade and much more expensive) for scratches--it did wonders even on the cab metal but for most of the job I used the cheap green stuff. I completely wore out 4 half sheets!
This is a "before" of the cleaned passenger side.
Red Max Pro Step 3 ready to apply.
Finished! It took me about 10 hours to do the job.
Plus I washed and waxed the cab. But by this time I was losing daylight so it is harder to see the shine.
I'm really pleased with the results. The recommendation is a new coat every year--that is a lot longer time period than waxing.
This was a good project for the start of a great season. I think it was worth the effort!
  • Here's a before/after of my 94 Adventurer
    Taken today, plan to finish next week.
    Apply a thin coat and let it dry. Give it 4 coats and you're done, no buffing.
    The reflection is a metal garage.
  • Cleaning Tire Cover
    Clorox Clean-Up in a spray bottle.
    Spray, wait, wipe off.
    Will look like brand new! :C
    Looks good, really shines.
    When you apply the Red Max Pro does it dry and then
    have to be buffed?
  • Looks good, Thats something thats on my "to do list" right after the install new floor, intall new captian chairs, install new insert trim, remove and repaint decals, get gen running and etc (you get the picture). But for a $20 investment and a days worth of work you can't beat the results.
    JKaz
