AZAmmochief
Jun 17, 2016Explorer
Typically you have four shocks, two front, two at the rear. I just purchased a set of Bilstein shocks for my MH from Shockwarehouse.com. This website made it pretty easy to find the right set for your application. The have most of the big name brands including Koni.I replaced them myself which wasn't that difficult. The key is to have the right tools, usually a large socket and breaker-bar. The nuts are on very tight. You also need to make sure you can crawl under the coach, it can be a pretty tight fit. To preview the task, look at YOUTUBE, searching for changing shocks. It took me about two hours total to change all four shock. The time you spend can save you almost $600 in labor costs. Good luck.
