RJL
Jun 01, 2017Explorer
Shore charging
I'll be storing my RV at home now, the storage facility we used is doing away with their outdoor storage. Over the years I typically would bring it home and charge it once a month for a day or so. N...
Jim@HiTek wrote:ArchHoagland wrote:
Mine is stored by my house and plugged in 24/7. I check the 2 six volt house batteries about once a month and usually have to add some distilled water.
Other than that everything else is fine.
I'm surprised you have to add water so often. A '04 Class A, especially a Monaco, I'd have expected that you would have a smart charger system in your Converter. But, sounds like you have a plain old charger, and it's running high voltage so it's boiling out water.
Couple things you could do...fully charge the batteries and then just disconnect the ground(s). They'll do fine (as long as they're healthy to begin with) over the winter, you won't even have to check them. You could disconnect from power.
Or, if you prefer to remain powered, try this:
Add 2oz of 3-in-1 oil to each battery cell. It's mineral oil, and it will keep the acid water inside the cell instead of it slowly bubbling out. So you won't need to add water as much, if at all. Also prevents corrosion buildup. Using mineral oil in flooded cell lead/acid batteries is a method used for over 100 years, even Edison recommended it.
