enblethen
Feb 23, 2016Nomad
Yes. Buy a range receptacle at your local hardware store. A surface style will work. Range Recept But a good quality 12 gauge extension cord.
Cut off the female end on the extension cord.
Strip back cut off end to gain enough insulated black wire. Connect the black wire to the parallel terminals brass colored screws. Make sure the wire between the two terminals is insulated and not touching any other terminals.
Connect the green wire to the green screw
Connect the white wire to the silver screw terminal.
You should change the title. You want to change from 50 amp to 15/20 amp, not 110.
