When you start the generator the transfer switch will disconnect the incoming shore power connection and your coach will be powered by the generator only. The generator is always the primary power source so you cannot run the generator and still have incoming power unless you kill the breaker at the generator to prevent power from coming into the coach. This is a good thing as not only do you want to know if the generator works, but you want to run it under load from time to time to keep it in good operating condition. When you shut down the generator the shore power will be restored automatically via the transfer switch.
