- Executive45Explorer III
cbshoestring wrote:
Executive wrote:
All the above is correct...however, I'll add one other tidbit...
White is ALWAYS neutral.
Green is ALWAYS ground.
ANY OTHER COLOR is ALWAYS hot....it could be orange red black purple etc...it's ALWAYS HOT.....Dennis
To the OP.. if you're buying a PLUG/MALE, it's a NEMA TT30P...the RECEPTACLE/FEMALE is a NEMA TT30R... make sure you get the right one. If it's not marked TT, its the wrong one. DO NOT USE THE NEMA 10-30....Dennis
Not to get totally technical, but..... If the power is running thru a light/fan box, the electrician should run the HOT on a WHITE wire down to the switch, which brings BLACK back up HOT to the light/fan/whatever. I have seen them NOT do this, which brings WHITE back up HOT. Not the prefered method, but I have seen it.
ALWAYS test.
I hate to see someone get zapped ASSUMING white is always nuetral. Although, I guess they wouldn't get zapped if they shut the power off. Either way, testing for hot would probably be best if you are not removing a black wire---replacing a black wire, etc...
ALWAYS ALWAYS ALWAYS...Check with a meter to be sure.
Just to be clear, anytime the white and/or ground is run as a different color than that which I posted, that wire is supposed to be taped with the correct color. In the example above, the WHITE wire should have been wrapped with BLACK tape for the last 8-12" indicating it is HOT....Dennis - cbshoestringExplorer II
ALWAYS test.
I hate to see someone get zapped ASSUMING white is always nuetral. Although, I guess they wouldn't get zapped if they shut the power off. Either way, testing for hot would probably be best if you are not removing a black wire---replacing a black wire, etc... - Executive45Explorer IIIAll the above is correct...however, I'll add one other tidbit...
To the OP.. if you're buying a PLUG/MALE, it's a NEMA TT30P...the RECEPTACLE/FEMALE is a NEMA TT30R... make sure you get the right one. If it's not marked TT, its the wrong one. DO NOT USE THE NEMA 10-30....Dennis - bsinmichExplorerI am still wondering how you have a female receptacle on your power cord. Did you learn about the birds and bees? My '96 Pace Arrow had ATS so no need for a female receptacle unless it is an extension cord.
Riverchaser wrote:
Have 2000 Pace Arrow Vision
Need to replace female plug on the shore power cord.
Green wire is ground
Which...White or black wire to carry the 110 volts???
Previous post are correct:
Black is death
White is neutral
Green like the grass is ground.
Dark wire to dark screw, white wire to light screw. green to green.
HOWEVER....remember that the neutral wire returns the "power" back to the source. It essential becomes a "hot" wire if the circuit is completed (ie...light is on). Not something you needed to know for replacing a power cord, but important if you are playing around near a live circuit. I have seen people think they could play with the white on an open circuit Actually a closed-hot circuit. open circuit is something completely different. read open as HOT....they got tickled.
I added that last bit, because it concerned me that you asked which wire carried the voltage.....both do. - BTPO1Explorer
Gary. wrote:
I bought one of those Male plugs from Lowes or Home Depot and the 3 prongs would not line up with a real 30 amp female receptacle?
I'll just toss this out there. Maybe the male plug that you bought at Lowe's or Home Depot was not a 125 volt RV plug, but a 250 volt plug. Was the "Real" 30 amp female receptacle a 250 volt receptacle or a 125 volt RV receptacle? - 352Explorer IIWould also like to mention they have what they call liquid electrical tape on the market to completely seal the connection from any condensation. Home Depot, Lowes and Ace Hardware.
- Gary_Explorer III bought one of those Male plugs from Lowes or Home Depot and the 3 prongs would not line up with a real 30 amp female receptacle?
- cmarqExplorerLowes and Home depot have the 30 amp rv plugs too. Make sure you have the wire all the way in the terminal and tighten the screw really tight loose connections are a big cause of fires.
38,782 PostsLatest Activity: Aug 31, 2026
