Xlerator wrote:
Any idea of where the transfer switch is located. My coach does have the 50amp Intellitec EMS model 900.
The above caught my eye. Behind the cover over the circuit breakers, you will probably find a small circuit board for your Intellitec. Pull the onboard fuse, leave it out for approx. 60 seconds and replace. This will probably solve the problem. Also gives you a chance to tighten all wire connections while you are in there.
About page 6 in this pdf is a pic of the circuit board showing the fuse I'm talking about. There is also a troubleshooting section.
