TucsonJim
Feb 15, 2015Explorer II
If all the power works with the generator, but not shore power plug in, then you need to determine what is different between the two. Here's what I'd check first:
1. Fault with the shore power pedestal.
2. Are you using a different adapter with the generator than you are with the pedestal? If so, is that your cause?
3. You aren't using a different power cord with the generator than you are with the pedestal?
38,769 PostsLatest Activity: Apr 03, 2026
