fischer
Aug 18, 2015Explorer
I had a southwind 2005. Under the hood you have a BCC battery control center. Inside it has 3 relays
main , aux and charge relays. Try pushing you aux button on your dash with the engine not running, That button ties both battery's together. The ground for your coach battery goes to the chassis and is bolted . Mine came loose once And I had similar symptons
