RLS7201
Apr 17, 2016Explorer II
dougrainer wrote:Blaster Man wrote:RLS7201 wrote:
Yes, your Fleetwood coach is designed to charge all batteries when on shore power or generator. That has been a Fleetwood feature since the early 90s.
Richard
95 Bounder
Not always so. On my coach, shore power charges the coach batteries, but has to be putting out at least 13.3 volts for the coach batteries to let the charge go through to the chassis batteries. I found this out the hard way when the chassis batteries were dead and the coach would not start.
Yes, this is true of ALL motorhomes that have the Intellitec BIRD system. In theory, the system should keep the chassis up, but will fail to keep the Chassis if the voltage drops to float charge. Newmar uses the BIRD system but installed a small solar charger just for the chassis batteries to keep the chassis charged when the BIRD went to float. A way to fool this system if leaving plugged in for weeks at a time, is every 7 days or so, to disconnect Shore Power for a few seconds and reconnect. That will make the Coach charging system go to bulk charge and go over the 13.3 volt threshold. Doug
All the rhetoric about various brands of coaches. A quick look at the OPs profile will reveal that he has "34' 1999 Fleetwood Discovery".
Which has a RV Custom Products Battery Control center, that is designed to charge all batteries under all conditions.
Richard
38,782 PostsLatest Activity: Sep 10, 2026
