mdgaluszaExplorerSep 23, 2016Shore powerWhen I plugged in my 50 amp line. Only some of my electronics worked. Back AC, micro, some outlets all worked. Front AC, tv,other outlets didn't st all. What could it be?
wolfe10ExplorerSep 23, 2016If all the circuits that are not working are fed through an inverter/charger, check the breakers ON the inverter charger.If OK, check for a tripped GFI-- the bathroom and kitchen are likely GFI locations, though some coaches have them in the basement.
Related ContentShore power questionGenerator/Shore Power Work, Battery Power Doesn'tDC power vs shore powerShore power plug conversion?Ok to run shore power without battery?
