mdgalusza
Sep 23, 2016Explorer
Shore power
When I plugged in my 50 amp line. Only some of my electronics worked. Back AC, micro, some outlets all worked. Front AC, tv,other outlets didn't st all. What could it be?
usersmanual wrote:wolfe10 wrote:
If all the circuits that are not working are fed through an inverter/charger, check the breakers ON the inverter charger.
If OK, check for a tripped GFI-- the bathroom and kitchen are likely GFI locations, though some coaches have them in the basement.
wolfe?? did u read any of the replys? the OP clearly says his front AC is not working? they don't run through a GFI or a inverter
that's why I suggested trying a 30 amp outlet to see if he gets his power back in those lines or not
