moisheh wrote:
Gjac. My Bounder is 34 ft. Gas MH's that are 32 to 34 ft. handle horribly. Look at the overhang! The front end usually has a GVW of about 10,000 and the rear 17,000. In 06 Fleetwood went to a 12,000 FE and a 19,000 rear. They have since gone back to a 10,500 FE and a 17,500 rear on the short Excursions.. The Tiffin is very light on GVW. When weighing the coach you are looking for side to side balance. The FA and RA will be very different. It is not unusual to find one side of an axle weighing 1000 lbs. more than the other. This can cause handling problems. That Breeze might be at the weight limits of one of the axles. That too is not unusual. I would suggest you take a few coaches for a test ride and experience the handling.
Moisheh
HAHAH. How many and which 32-34' gassers have you taken for a test drive to form that opinion? I'm sure you follow your own advice on that one right?
