dougrainer wrote:
Then see if you have the short? Doug
The ignition switch is out of the system. What is tripping the short is the IGN pole.
The coach system is on a circuit board, all coach systems are routed thru that circuit, That was been changed, no difference.
The Spartan circuits in the coach operate normally, the only thing that is wrong is the IGN system.
all signal lights work, back up camera, all external lights work.
Spartan's skit, shows a direct circuit to the Transmission computer and the ECU, the Transmission computer that has been disconnected. still shows a short.
I'm in process disconnecting ECU.
stay tuned
