NCC-1701
Mar 28, 2018Explorer
Joe, some things sound like they might be simple...like a water heater that is not firing up. Probably needs to have a good cleaning done, which would be normal maintenance. A generator with only 71 hours on it and it's 18 years old tells me it was not exercised, as it should be, on a monthly basis.
Two things stand out to me as something that could be major: 1) if there's water under a motorhome after someone takes a shower, there could be rot, mold, or other water damage under the floor. 2) For me personally, delaminimation is a non-starter. This means moisture has probably penetrated the walls causing the delamination, which is not an easy fix, or cheap.
