Trackrig
May 11, 2016Explorer II
I've run several Jeeps. Aggressive tires are usually more expensive and don't wear as well. Once half of the tread is gone they're usually not very good off of the road.
Different tires aren't going to help mileage at all. If you'll use the stock wheels again later to get your money out of them, then that's not a bad idea. If you'll never use them again, leave them sitting in the garage where they're in the way and eventually give them away, then no, run the aggressive tires and replace them when when needed.
Bill
Bill
