2bzy2c
May 29, 2013Explorer II
Geocritter wrote:
This isn’t the news I was hoping for, however the roof on my HR is slightly rounded so at least it doesn’t puddle on top. The other day I climbed up and took off the shroud. The photo is of the discharge hole for the water.
I’m thinking I can fabricate a small thin plastic catch-tray to slide between the shell and the roof under the hole. Then run a tube from the tray off past the edge of the roof. This would be a temporary setup and used primarily at month or longer stops.
Steve
Just because most RV's just let the water run off of the roof, does not mean you can't improve it.
I like your idea of routing the water down a tube.
38,766 PostsLatest Activity: Jan 10, 2026
